Again(Datetime in Addrealtime does not work)
M.Takeda
Post by M.Takeda » Wed Jan 18, 2006 11:03 am
Thank you for your prompt reaction.
But your suggestion does not solve my problem.
No.1 is your example and No2 is modified it.
No.1 program work fine but No.2 does not work correctly.
Please check again and teach me what is wrong. Thank you in advance.
'------------------------------- No1 --------------------------------------
Dim t As Integer
Private Sub Form_Load()
With TChart1
.AddSeries scFastLine
.TimerEnabled = True
.TimerInterval = 100
End With
Private Sub TChart1_OnTimer()
t = t + 1
TChart1.Series(0).asFastLine.AddRealTime t, Cos(t), "", clTeeColor
'------------------------------No2(fro example)--------------------------------
Dim t As Double
With TChart1
.Series(0).XValues.DateTime = True
.TimerInterval = 1000
End With
t= CDbl(Now)
t = DateAdd("s", 1, t)
Post by Pep » Fri Jan 20, 2006 4:37 pm
if you want the exmple No.2 work in the same way as the example No.1 but showing datetime axis labels you should use the following code :
Dim t As Double
With TChart1
.Axis.Bottom.Labels.Angle = 90
.Axis.Bottom.Labels.DateTimeFormat = "hh:mm:ss"
End With
t = CDbl(Now)
t = DateAdd("d", 1, t)
