TChart_OnClickSeries Problems in bubble-series
Chris L
Post by Chris L » Thu Feb 05, 2004 3:28 pm
I use TeeChart v6 to create a bubble-series.
I want to change the color of a bubble when I click on it, so I use the TChart_OnClickSeries event.
With the ValueIndex, which I got from the event, I can change the color of the nearest bubble, on which I clicked.
But when I've got two bubbles on the same position with a different radius and I click on the outer bubble, the inner (smaller) bubble changes color.
I only get the ValueIndex of the greater bubble, when I click outside the bubble, which is not very useful!
What can I do?
Thanks for help
V. Ri.
Post by Pep » Thu Feb 05, 2004 5:21 pm
you're correct, it does not work fine either in the v6.04. I've added this bug on our defect list. A fix for it will be considered to inclusion for the next maintenance release v6.05.
Chris L
Post by Chris L » Wed Feb 11, 2004 9:36 am
When would this new release be available?
I need a solution very quickly.
Thank you
V.Ri.
Post by Pep » Wed Feb 11, 2004 10:01 am
there's no date fixed, but I think it will be ready in one or two months.
