Isometric axis by default?
Alex
Post by Alex » Thu Aug 05, 2004 9:12 am
Hello!
In the v7 is the feature "isometric axis" included :D . Two questions:
-Is there a switch to make the axis isometric by default (e.g. the whole Tchart-diagramm)? :?: Is there somewhere a switch in the teecommander -> edit to adjust during execution?
- it looks like the automatic.axis.offset is not considered in calculating the isometric ratio, is this a bug?
Thanks in advance!
Best regards
Alex
Post by Pep » Tue Aug 10, 2004 11:31 pm
Hi Alex,
-Is there a switch to make the axis isometric by default (e.g. the whole Tchart-diagramm)? Is there somewhere a switch in the teecommander -> edit to adjust during execution?
There's no way to set it as default, you will have to do it by code.
Yes, you're correct , it should be considered too. We'll take a look for the Final release (which will be out on this week) or in the next maintenance release.
