How to draw a circle ring and a arc segment?
David
Post by David » Mon Mar 01, 2010 8:00 am
I don't know if I am using the correct phrases, but here are what I want to plot.
1) Circle ring: the area in middle of two circles with radius r1 and r2 and fill it up with some color.
2) arc segment: a fraction of the circle ring from angle a1 to a2, which consists of 4 lines. One arc with radius of r1, one arc with radius r2 and the two lines connecting the two arcs.
For example, r1=5cm and r2 = 10cm, the circle ring will be the area between the two circle edges, and a arc segment could be from 30 to 60 degrees of the circle ring.
So how to draw these two items? There is no shape series for them.
Re: How to draw a circle ring and a arc segment?
Post by Yeray » Mon Mar 01, 2010 4:37 pm
Hi David,
I'm afraid that there is no TeeChart function right now to do this automatically. The only way I can think right now would be drawing a custom polygon with TeeChart's Canvas.Polygon method but you should calculate all the ring coordinates manually.
David
Post by David » Tue Mar 02, 2010 1:27 am
Got it. Thanks.
