Loading the sample error
Candy
Post by Candy » Tue Jan 04, 2011 1:34 am
I loaded the sample("Steema Software\TeeChart Pro v2010 ActiveX Evaluation\Examples\Visual C++\Version 6\Automation") in the VC ,but it happens the following error
--------------------Configuration: Automation - Win32 Release--------------------
Compiling resources...
C:\Program Files\Steema Software\TeeChart Pro v2010 ActiveX Evaluation\Examples\Visual C++\Version 6\Automation\Automation.rc(214) : 致命错误 RC1015: 无法打开包含文件 'res\Automation.rc2'.
执行 rc.exe 时出错.
Automation.exe - 1 error(s), 0 warning(s)
What should I do? Thanks!
Candy
Re: Loading the sample error
Post by Yeray » Tue Jan 04, 2011 12:11 pm
Hi Candy,
I can't reproduce the problem with that example.
Here you have the actual version of it. Could you please check it?
Automation.zip
(566.61 KiB) Downloaded 628 times
