TeePreviewPanel ActiveX
Seth
Post by Seth » Wed Dec 22, 2010 4:49 am
I have another question.
We distribute TeeChart7.Cab to out customer's PC.
We received an inquiry that when TeeChart7.cab distributed, TeePreviewPanel ActiveX was installed together.
Is TeePreviewPanel ActiveX embedded Teechart7 ActiveX?
Re: TeePreviewPanel ActiveX
Post by Yeray » Wed Dec 22, 2010 8:46 am
Hi Seth,
In the Cab files folder you'll find a Readme.txt that says:
TeeChart Pro 7.06 Cab files
Contents
Both CAB files are authenticoded.
teechart7.cab
Cab file of regular teechart.ocx file.
Use this file where full functionality is
required.
teesmall7.cab
TeeChart Cab file, reduced functionality.
The file is a smaller alternative for
applications which do not require TeeChart's
full functionality set and for which size and
resultant network transfer speed are important.
Functionality missing from teesmall.cab:
- No TeeChart Editor
- No JPEG support
- No Print Previewer
- No About screen
- No ODBC access
- No OpenGL
Should you have any different requirements for a
reduced (file) size TeeChart Control please let us
know, your feedback would be welcome !
Seth
Post by Seth » Thu Jan 20, 2011 6:01 am
Hi, I write this question, again.
Because I don't want to know that what files are in TeeChart7.CAB
I just want to know whether Teechart7.ocx and TeePreviewPanel ActiveX are related or not.
When my client downloaded Teechart7.cab and installed, TeePreviewPanel was installed in system folder, too.
Are they related?
Please check this problem.
Post by Narcís » Thu Feb 03, 2011 4:27 pm
Hi Seth,
Apologies for the delayed reply.
Yes, TeeChart7.ocx COM component contains a component set among them being: TeePreviewPanel, TChart, TeeCommander, etc. All the components visible in the toolbar when enabling it.
