Post
by Yeray » Wed Jul 11, 2012 2:08 pm
JAV wrote:ok you caught us!
Effectively it is the same discussion! And it is because we still haven't solved the problem: Our IDE works the same as VB6, we have maximized the frame and with resize event we've maximized the activeX, it means, we adjusted the ActiveX to our frame, but the image looks truncated, as we showed in the previous post.
Please, tell us something different, we've already tried every instruction you gave before.
I've merged both threads for clarity.
So, using the Resize event as suggested in
this post doesn't solve the problem? Have you debugged the code to see if the event is being fired?
JAV
- Newbie
Post
by JAV » Thu Jul 12, 2012 6:34 pm
Debugging is done effectively and the event runs, that is why the image gets bigger, but the activeX not, is for that reason that the image is truncated. Is there any sentence that is lacking?
Post
by Yeray » Mon Jul 16, 2012 11:27 am
We should discard the IDE (or a particularity on it) to be causing it. It would be helpful if you could give it a try to the Visual Studio (the Express version is free) to see if the problem also happens on it.
http://www.microsoft.com/visualstudio/e ... ns/express
