Color band in PDF export
Raymond
Post by Raymond » Fri Oct 30, 2009 8:45 pm
I have color band on my chart. However, when I export to PDF, the color band does not get drawn. Is there a workaround?
Re: Color band in PDF export
Post by Yeray » Mon Nov 02, 2009 10:31 am
Hi Raymond,
There is a bug already in the wish list that says that the patterns for this tool aren't exported fine to pdf (TV52011702). The colorband is drawn but in white. Is that what you mean?
Raymond
Post by Raymond » Mon Nov 02, 2009 5:41 pm
Yea, I suppose the color band is not being drawn at all because if I change the backwall color, the export shows the backwall color.
Post by Yeray » Tue Nov 03, 2009 9:11 am
Hi Raymond,
Are you using the v8.0.0.7 that is the latest version available? Here the following code gives the same result: A ColorBand in white.
Private Sub Form_Load()
  TChart1.Aspect.View3D = False
  TChart1.AddSeries scPoint
  TChart1.Series(0).FillSampleValues 25
  TChart1.Tools.Add tcColorband
  TChart1.Tools.Items(0).asColorband.Axis = TChart1.Axis.Bottom
  TChart1.Tools.Items(0).asColorband.StartValue = 10
  TChart1.Tools.Items(0).asColorband.EndValue = 15
  TChart1.Export.asPDF.SaveToFile "C:\tmp\ColorBand.pdf"
  TChart1.Tools.Items(0).asColorband.Brush.Style = bsBDiagonal
  TChart1.Export.asPDF.SaveToFile "C:\tmp\ColorBandBrush.pdf"
