TeeChart eval 2010.
TonyVSUK
TeeChart eval 2010.
Post by TonyVSUK » Mon Nov 29, 2010 4:32 pm
Hello all,
I downloaded and installed this today, but it will not run for me. It says the trial has expired.
I haven't installed it before. Is there anything I can do to have a go for a few hours?
Tony.
Re: TeeChart eval 2010.
Post by Yeray » Mon Nov 29, 2010 4:49 pm
Hi Tony,
Are you sure you haven't installed an eval version before?
Have you checked that you've run the installer with high privileges and no security software was blocking its registry writing attempt?
If you are sure about it, tell us and we'll send you an eval extender utility.
TonyVSUK
Post by TonyVSUK » Mon Nov 29, 2010 4:58 pm
Absolutely positive I haven't installed it before.
And I'm on XP, and logged in as Administrator, so it shouldn't be a permissions issue.
If you can send me an extender that would be great. I only need it for a couple of days.
Tony.
Post by Yeray » Tue Nov 30, 2010 10:50 am
Hi Tony,
I've just sent it to the mail you have registered in this forums.
Note that if the application says that it can't find the expiration date it may be that the evaluation installer failed when tried to write into the registry. In that's the case, please try reinstalling the evaluation version ensuring that no security software is blocking it to write in the registry.
TonyVSUK
Post by TonyVSUK » Tue Nov 30, 2010 11:07 am
Thanks it's working fine for me now.
Tony.
