FastLine not redrawing
Neil
Post by Neil » Mon Sep 06, 2004 4:26 pm
I'm using CFastLineSeries for extra speed, and everything works well when adding points where the x value is increasing.
When I add values where the x value is decreasing, nothing gets shown until another 'event' happens (e.g. new tools created, or screen manually repainted).
Is there a fix for this?
I'm using TeeChart V5 ActiveX under VC 6.
Neil
Post by Pep » Mon Sep 06, 2004 6:13 pm
Hi Neil,
which code are you using ? I cannot reproduce the problem here. Could you please tell me the steps to reproduce it or send me a simple example ?
Neil
Post by Neil » Tue Sep 07, 2004 10:06 am
You will only see this effect if you add the points over a period of time (ie with a SetTimer).
I have a visual C++ example program I can send.
What email address can I send it to?
Neil
Post by Pep » Tue Sep 07, 2004 10:19 am
Hi Neil,
yes, please send me it directly to pep@steema.com
Neil
Post by Neil » Wed Sep 08, 2004 7:44 am
I sent it yesterday. Did you receive it?
Can you see the problem?
Neil
Post by Pep » Thu Sep 09, 2004 4:23 pm
Hi Neil,
yes, I've received it. The problem is in the :
void CGraphTestView::OnTimer(UINT nIDEvent)
Make sure you set the sort order of the valuelists to none, e.g.
#endif // EVENTMARKER
if(m_pData >= &data[_countof(data)-1])
m_Direction = -1;
m_Series = m_cChart.Series(m_cChart.AddSeries(lineType));
m_Series.GetXValues().SetOrder(loNone);
m_Series.GetYValues().SetOrder(loNone);
#ifdef FASTLINE
