Question about On click series
Cliven
Post by Cliven » Wed Sep 15, 2004 1:30 am
When the Tee Chart is in Horizontal Bar, the onClick Series Event not fired. Is anybody know what problem is that and how to slove it?
Thank you.
Post by Pep » Wed Sep 15, 2004 10:02 am
Hi Cliven,
it works fine here with the TeeChart Pro v6 and v7, wich teechart pro version are you using ?
Cliven
Post by Cliven » Thu Sep 16, 2004 3:01 am
oh...... i'm using TeeChart Active X version 5 . so, is there any solution for this version?
Thx alot.
Post by Pep » Thu Sep 16, 2004 8:21 am
Hi Cliven,
are you using the latest maintenance v5.06 ?
I've test it with it and works fine here. You can download it from our web site at the "private customers download page".
Cliven
Post by Cliven » Mon Sep 20, 2004 10:32 am
I downloaded the maintenance before it already, but the problem insist.
Have you tried to create around 10 something series, and change it to horizontal bar?? The event not fire when i doing as this.
Thank you.
Post by Pep » Mon Sep 20, 2004 11:10 am
Hi Cliven,
I've posted one example into the steema.public.attachments newsgroup which works fine here with the v5.06. Could you please test it and modify it so I can reproduce the problem here ?
Cliven
Post by Cliven » Tue Sep 21, 2004 6:18 am
yes, the example that you post is work fine, but i still face the same problem ( we are using OCX ).
anyway, thanks alot. Very appreciate.
Post by Pep » Wed Sep 22, 2004 9:23 am
Hi Cliven,
then, in case you think that the problem is in the TeeChart component please send me an example with which I can reproduce the problem "as is" here.
