change series draw order
corwl
Post by corwl » Tue May 01, 2012 2:56 am
Hello all,
I have chart with several series.
some part of series is hidden by other series above them,
so I would like to change the drawing order of series at run-time.
How can i do it without changing series index?
best regards,
iblee
Re: change series draw order
Post by Sandra » Wed May 02, 2012 9:20 am
Hello iblee,
I suggest you use property ExchangeSeries of TChart as do in next code:
Private Sub Form_Load()
TChart1.AddSeries scLine
TChart1.Series(1).FillSampleValues
TChart1.ExchangeSeries 0, 1
Can you tell us if previous code works as you want?
corwl
Post by corwl » Wed May 23, 2012 4:33 am
Thank you for your reply.
Your answer changed the order of drawing but,
changed the series index too.
In my application series index is associated with other variables so that it must maintain it's index.
Is there any solution that can change the order of drawing while maintaining series index?
regards,
iblee
Post by Yeray » Wed May 23, 2012 10:40 am
Hi iblee,
Yes, you can invert the Depth axis:
TChart1.Axis.Depth.Inverted = True
corwl
Post by corwl » Fri May 25, 2012 8:55 am
Hi Yeray
I am really appreciate your help.
In my chart, many series are overlapped and I want one arbitrary series to be drawn on the top.
Can drawing order be controlled in arbitrary way?
Best regards
iblee
Post by Yeray » Fri May 25, 2012 9:25 am
Hi iblee,
I'm afraid not.
The only possibilities I see are the suggested above. Concretelly, regarding the first suggestion about using ExchangeSeries to sort your series as you wish, you said:
corwl wrote:In my application series index is associated with other variables so that it must maintain it's index.
I guess you could add some logic to maintain a table of indexes to maintain your relations.
