The SaveToFile function fails when adding Series Circular
Chen Yang
Post by Chen Yang » Fri Aug 10, 2012 10:56 am
The version of TeeChart is 2010.0.0.3, SaveToFile funtion fails when adding Series Circular Gauge to TeeChart.Please see the following test Code
#include "stdafx.h"
using namespace std;
void RunTeeChart( );
int _tmain(int argc, _TCHAR* argv[])
CoInitialize(NULL);
RunTeeChart( );
CoUninitialize();
return 0;
void RunTeeChart( )
using namespace TeeChart;
ITChartPtr chart1;
_com_util::CheckError(chart1.CreateInstance(__uuidof(TeeChart::TChart)));
chart1->SetTheme(TeeChart::EChartTheme::ctDefault,TeeChart::EColorPalette::cpTeeChart);
chart1->AddSeries(scBar);
chart1->AddSeries(scCircularGauge); //if delete this line the SaveToFile function will works well
for (int i = 0; i < chart1->SeriesCount; i++)
chart1->aSeries->Clear();
chart1->Export->SaveToFile(L"new.tee"); // SaveToFile fails and throw an exception
please tell me how to use it correctly or give me a fix , thanks.
Haitao Sun
CA Technologies
Senior Software Engineer
Tel: +86-10-58162132
Fax:+86-10-58162300
Haitao.Sun@ca.com
Re: The SaveToFile function fails when adding Series Circular
Post by Yeray » Fri Aug 10, 2012 2:06 pm
Hi Chen,
I've translated your code to VB6 and it seems to work fine for me with both v2010.0.0.3 and the actual v2012.0.0.8
Private Sub Form_Load()
  TChart1.AddSeries scBar
  TChart1.AddSeries scCircularGauge
  TChart1.Export.SaveToFile "C:\tmp\new.tee"
  TChart1.ClearChart
  TChart1.Import.LoadFromFile "C:\tmp\new.tee"
Please, try to arrange a simple example project we can run as-is to reproduce the problem here.
Chen Yang
Post by Chen Yang » Mon Aug 13, 2012 1:35 am
you missed the following code
Please add this and test it again.
Post by Yeray » Mon Aug 13, 2012 8:42 am
Hi Chen,
Excuse me, you are right.
It seems there's a problem when exporting a CircularGauges that has been Cleared. I've added it to the wish list to be revised for next releases (TV52016300).
In the meanwhile, you could give a Value to this series before exporting it. Ie:
TChart1.Series(i).asCircularGauge.Value = 0
