Smooth serie Convert from 6 to 7
Hans
Post by Hans » Fri Nov 19, 2004 10:04 am
I upgraded my chart project from 6 to 7. I used the smooth function on a line that's going up to a certain maximum and is going back again thus the line draws a hysterese. The smooth in version 6 did show also after smoothing the hysterese. After upgrading to version 7 this is not the case anymore. :( The smooth line connects the points of the up going line with the down going line so a zigzag line is drawn.
Could you tell me why this is? As I read you use now dynamic array, could this be the problem now?
Post by Pep » Mon Nov 22, 2004 7:49 am
Hi Hans,
it should work in the same manner for both versions. Could you please send me a code with which I can see the difference using it in v6 and v7 ?
