Wrong *.tee file format error
Sophie
Post by Sophie » Tue Dec 14, 2004 10:17 pm
I receive the following error when I call TChart1.Import.LoadFromURL("http://www.myweb.com/mychart.tee") from an IE browser running vbscript client side code, on a terminal server session only.
Can you help me??
Post by Pep » Wed Dec 15, 2004 12:25 am
if this only happens on Terminal Server Session the problem could be related with the permissions. Do other examples like the included in the TeeChart Pro ActiveX installation work fine ?
Sophie
Post by Sophie » Wed Dec 15, 2004 5:05 pm
Always with an TeeChart Pro ActiveX inan IE browser running vbscript client side code,
I can access a XML in the same folder by
<xml src="http://www.myweb.com/mychart.xml" />
If I fill the chart in the script client with this data, no problem.
If I use the method LoadFromUrl to download the chart from a server side asp page or from a .tee file, I have this error on terminal server session, but never on normal computer.
And I have full access on the folder.
Sophie
