Rendering problems in PDF for TeeChart ActiveX Ver 6
pngny1
Post by pngny1 » Thu Jan 13, 2005 1:54 pm
I use the ActiveX TeeChart control on a webpage. When I export to PDF, the series in the resulting file are all black. Also, the axis title is not correctly positioned.
The color rendering problem was brought up in a previous posting:
http://www.teechart.net/support/modules ... opic&t=112
It seems as though the Steema person that responded, Marjan Slatinek, did not follow up on this issue. His response only stated that he could not reproduce the problem using the VCL version. Does not appear that he tried to reproduce w/ the ActiveX version.
Is this a confirmed bug in the ActiveX version? Is there a bug fix? Which version? I need help. thanks.
Paul Ng
New York, NY, USA
+1.212.538.8850
Post by Pep » Fri Jan 14, 2005 12:54 pm
Hi Paul,
please see my other post here
