Annotation ShapeBound.Right,Bottom doesn't work in Ver.7
Nitin
Post by Nitin » Wed Jan 19, 2005 4:50 am
We are using TeeChart ActiveX V.6 in our application and we are evaluating Ver.7. The problem I am facing is Annotation tool's ShapeBounds.Right and Bottom property always returns 0. In Ver.6 there was no problem and was working fine. So my problem is how to get Right and Bottom values so that I can know exact area of rectangle of annotation tool. Also Height and Width Properties return negative values.
Post by Pep » Fri Jan 21, 2005 5:11 pm
yes, you're correct, I can see the problem here. It's a bug, I've added it on our defect list, we'll try to fix it for the next maintenance release.
Thanks for the report.
