Listbox entries too small
Wirehead
Post by Wirehead » Thu Jan 15, 2004 4:45 pm
I use the ListBox control in a Window-based application under VC++ (not in a dialogue!)
When I add some Series to the chart, the spaces for the entries in the ListBox are as half as high as they should be. You can read the entries, but it looks terrible, because there is no space between two entries and the upper and lower part of the series type symbol is cut.
Funny is, if I use the control in a dialogue, everything is OK.
WH
Post by Pep » Fri Jan 16, 2004 9:52 am
could you please send me an example to the steema.public.attachments newsgroup so I can reproduce the problem "as is" here ?
Also, which TeeChart Pro version are you using ?
Wirehead
Post by Wirehead » Tue Jan 20, 2004 4:37 pm
That's v6.0.0.4
I use the Create method of the CTeeListBox class to place the control in my FrameWindow.
Post by Pep » Tue Jan 20, 2004 5:05 pm
Could you please send one example to the steema.public.attachments newsgroups with which I can reproduce the problem "as is" here ?
