wrong *.tee file format
Shannon Hord
Post by Shannon Hord » Tue Jan 27, 2004 6:31 pm
I am creating a web application in ASP.NET & ASP which is attempting to use TeeChart Pro ActiveX 6 to display data read from a SQL Server.
I am receiving an error msg "wrong *.tee file format" when I try to view a chart loaded from URL. I receive the same error in my app as well as the sample apps distributed with TeeChart Pro AX 6. I am confident that my 'GetChart.asp' page is working properly since the chart is correctly displayed if I save as png instead of native and view the GetChart page directly.
How can I remedy this situation?
Post by Pep » Thu Jan 29, 2004 11:02 am
Hi Shanon,
the problem could be related with the permissions. Make sure all is correct in your IIS/NTFS.
