Annotation Problem
norad
Annotation Problem
Post by norad » Thu Mar 11, 2004 3:26 pm
Hi all,
I am having trouble removing the Frame from an annotation Rectangle.
Is there a way to achieve this?
Post by Pep » Thu Mar 11, 2004 5:48 pm
you can do :
tChart1.Tools.Items(0).asAnnotation.Shape.Frame.Visible = False
norad
Post by norad » Thu Mar 18, 2004 11:57 am
I have tried to use the above code but i get an error on the asp page.
The following is the code i have used
With Chart
.Tools.Add tcAnnotate
.Tools.Items(2).Active = True
With .Tools.Items(2).asAnnotation
.Position = ppRightTop
.Shape.Gradient.Visible = false
.Shape.ShapeStyle = fosRectangle
.Shape.Font.Name = "Verdana"
.Shape.Font.Color = RGB(170,170,204)
.Text = "TEST"
.Shape.Shadow.Color = vbwhite
End With
End With
and the error i get:
Microsoft VBScript runtime error '800a01b6'
Object doesn't support this property or method: 'Shape.Frame'
Am i doing something wrong here?
Please help
Post by Pep » Fri Mar 19, 2004 2:45 pm
Hi norad,
Yes, you're correct, it's a bug. I've added it on our defect list and a fix for it will be considered to inclusion for the next maintenance releases.
norad
Post by norad » Tue Mar 23, 2004 7:59 am
Thanks for your reply, i will be waiting the maintenance release
Norad
