Legend Color
Legend Color
Post by » Mon Dec 01, 2003 8:04 pm
Hi!
I've had some troubles with the chart that have more than one series.
I'm trying to make one self stacked chart, and the color reference in the legend doesn't appear.
Please, review the following source code and tell me what is the problem.
(Put one TChart and a Command Button in a form)
Tks
Christian Sabino
Private Sub Command1_Click()
Dim iSer As Integer
iSer = TChart1.AddSeries(scBar)
TChart1.Series(iSer).Add 10, "Serie 1", clTeeColor
TChart1.Series(iSer).Add 20, "Serie 1", clTeeColor
TChart1.Series(iSer).Add 30, "Serie 1", clTeeColor
TChart1.Series(iSer).Marks.Visible = False
TChart1.Series(iSer).ColorEachPoint = True
TChart1.Series(iSer).asBar.MultiBar = mbSelfStack
TChart1.Series(iSer).Add 15, "Serie 2", clTeeColor
TChart1.Series(iSer).Add 25, "Serie 2", clTeeColor
TChart1.Series(iSer).Add 35, "Serie 2", clTeeColor
Post by Pep » Mon Dec 01, 2003 11:47 pm
Hi Christian,
this is by default, you cannot assign the Color for the legend symbol of one Series with multiple colors (I think this feature will be available for the next TeeChart Pro v7).
Also, if you want to show the Series color in the legend you can do something like this :
TChart1.Series(iSer).ColorEachPoint = False
TChart1.Series(iSer).Color = vbBlue
Josep Lluis Jorge
http://support.steema.com
Make a simple stacked bar chart
Post by » Tue Dec 02, 2003 12:44 pm
Tks for your response.
Now, I'm trying to make the following chart, I made first with Excel 2000. I have a table with the data and make a simple chart stacked column.
Muy.Dificil Dificil Media Facil Muy.Facil
02/11 33 3 3 1
9/11 28 4 3 1
16/11 27 2 2 1 1
23/11 19
30/11 26 1 1
1/12 30 1 1
Selecting this data and making a simple chart give the char that I want, but if I load this information in Tee make other chart. Maybe Tee is taking the series in other way.
This is the code
Dim iSer As Integer
TChart1.Series(iSer).Add 33, "02/11", clTeeColor
TChart1.Series(iSer).Add 28, "09/11", clTeeColor
TChart1.Series(iSer).Add 27, "16/11", clTeeColor
TChart1.Series(iSer).Add 19, "23/11", clTeeColor
TChart1.Series(iSer).Add 26, "30/11", clTeeColor
TChart1.Series(iSer).Add 30, "1/12", clTeeColor
TChart1.Series(iSer).Color = vbRed
TChart1.Series(iSer).Title = "Muy Dificil"
TChart1.Series(iSer).Add 3, "02/11", clTeeColor
TChart1.Series(iSer).Add 4, "09/11", clTeeColor
TChart1.Series(iSer).Add 2, "16/11", clTeeColor
TChart1.Series(iSer).Add 0, "23/11", clTeeColor
TChart1.Series(iSer).Add 0, "30/11", clTeeColor
TChart1.Series(iSer).Add 0, "1/12", clTeeColor
TChart1.Series(iSer).Color = vbYellow
TChart1.Series(iSer).Title = "Dificil"
TChart1.Series(iSer).Add 3, "09/11", clTeeColor
TChart1.Series(iSer).Color = vbGreen
TChart1.Series(iSer).Title = "Media"
TChart1.Series(iSer).Add 1, "02/11", clTeeColor
TChart1.Series(iSer).Add 1, "09/11", clTeeColor
TChart1.Series(iSer).Add 1, "16/11", clTeeColor
TChart1.Series(iSer).Add 1, "30/11", clTeeColor
TChart1.Series(iSer).Add 1, "1/12", clTeeColor
TChart1.Series(iSer).Color = vbWhite
TChart1.Series(iSer).Title = "Facil"
TChart1.Series(iSer).Add 0, "02/11", clTeeColor
TChart1.Series(iSer).Add 0, "09/11", clTeeColor
TChart1.Series(iSer).Title = "Muy Facil"
Please, I need to make this kind of chart for my app.
Tks again
Christian Sabino
Post by Pep » Tue Dec 02, 2003 7:58 pm
I think you should use the following code to see what you get what you want :
Dim iSer As Integer
TChart1.Series(iSer).asBar.MultiBar = mbStacked
Just changing the following line :
by :
Josep Lluis Jorge
