asp label access
adenin
asp label access
Post by adenin » Thu Mar 06, 2008 8:40 am
pls is it possible to access label set up with:
TChartSpeed.Series(1).AddXY 92 , 1001.07 , "sample label" , RGB(255,0,0)
in mouse event:
Sub TChartSpeed_OnMouseMove(Shift, X, Y)
I would like to display this label with yvalues in rectangle with annotation tool.
thanks
Post by Yeray » Thu Mar 06, 2008 8:57 am
Hi adenin,
If I understand well, you are trying to achieve something very similar than All Features/Tools/Annotation/Annotation Callout example in the new features demo, available at TeeChart's program group.
adenin
Post by adenin » Thu Mar 06, 2008 9:14 am
yes, something like that;
I have already found it:
mouseOverIndex = TChartSpeed.Series(1).Clicked(X, Y)
If mouseOverIndex <> -1 Then
TChartSpeed.Tools.Items(0).Active=True
TChartSpeed.Tools.Items(0).asAnnotation.Text = "value:" & TChartSpeed.Series(1).YValues.Value(mouseOverIndex) & Chr(13) & "label:" & TChartSpeed.Series(1).PointLabel(mouseOverIndex)
Post by Yeray » Thu Mar 06, 2008 9:18 am
Hi adenin,
I've made an example using two functions in the demo I've pointed to you before. Note that for me, the series index is 0, and for you is 1.
Private Sub Form_Load()
  With TChart1
    .Aspect.View3D = False
    .Legend.Visible = False
    .AddSeries scPoint
    For i = 0 To 49
      .Series(0).AddXY i, Rnd * 1000, "Point number " + Str$(i), RGB(255, 0, 0)
    Next i
    .Axis.Bottom.Labels.Style = talValue
    With .Tools
      .Add tcAnnotate
      With .Items(0).asAnnotation
        .Left = 300
        .Top = 15
        .Text = TChart1.Series(0).PointLabel(0)
      End With
    End With
  End With
' Returns Series point index that is nearest to xy position.
Function NearestPoint(ByVal X As Long, ByVal Y As Long) As Long
Dim Difference As Long, tmpDif As Long, i As Long, res As Long
  res = -1
  Difference = -1
  For i = 0 To TChart1.Series(0).Count - 1
    tmpDif = Round(TeeDistance(TChart1.Series(0).CalcXPos(i) - X, _
                               TChart1.Series(0).CalcYPos(i) - Y))
    If (Difference = -1) Or (tmpDif < Difference) Then
      Difference = tmpDif
      res = i
    End If
  Next i
  NearestPoint = res
End Function
Function TeeDistance(ByVal X As Integer, ByVal Y As Integer) As Double
  TeeDistance = Sqr(X ^ 2 + Y ^ 2)
End Function
Private Sub TChart1_OnMouseMove(ByVal Shift As TeeChart.EShiftState, ByVal X As Long, ByVal Y As Long)
Dim i As Integer
  i = NearestPoint(X, Y)
  TChart1.Tools.Items(0).asAnnotation.Text = TChart1.Series(0).PointLabel(i)
