CircularGauge Look
Re: CircularGauge Look
Post by Yeray » Tue Jun 12, 2012 9:46 am
Hi Mulderone,
Ah, I didn't understand you correctly.
I've added it to the wish list to see if we can align the gauges better in the center.
Mulderone
Post by Mulderone » Wed Jun 13, 2012 2:49 pm
when can I expect this improvement ?
Best regards
David
Post by Yeray » Thu Jun 14, 2012 3:38 pm
Hello David,
I've seen it should be already possible if the Chart's VerticalOffset property worked with the Gauges as it does in TeeChart .NET.
However, I can't tell you when this will be revised. We are preparing the next maintenance release but I don't think we'll be able to put this into it.
Mulderone
Post by Mulderone » Thu Jun 14, 2012 6:16 pm
Yeray,
i understand your constraint with the release planning, but it's possible to get this correction earlier, as source, which i can integrate in my personal TeeChart.jar version, without pending the next delivery ?
Thanks for your help
Best regards
Post by Yeray » Fri Jun 15, 2012 3:07 pm
Hi David,
Mulderone wrote:i understand your constraint with the release planning, but it's possible to get this correction earlier, as source, which i can integrate in my personal TeeChart.jar version, without pending the next delivery ?
I've added this thread to the ticket description (TJ71016221), so we should contact you when we'll find a solution for it.
On the other hand, being a source code customer allows you to look for the root of the issue yourself and hopefully find a solution sooner than us :)
Mulderone
Post by Mulderone » Sat Jun 16, 2012 11:11 am
Ok, thanks for all
Best regards
David
Mulderone
Post by Mulderone » Thu Sep 06, 2012 11:32 am
no news about my ticket ?
I've read the release note and no correction for this.
Post by Yeray » Thu Sep 06, 2012 11:41 am
Hi David,
Right. I'm afraid it hasn't been fixed yet.
Mulderone
Post by Mulderone » Thu May 30, 2013 9:54 am
Any news about the TJ71016221 ticket ?
Post by Yeray » Thu May 30, 2013 1:49 pm
Feel free to follow the following channels for new release announcements: this forum, RSS news feed, Twitter and Facebook
And check what's implemented on each new release looking at the public release notes:
https://www.steema.com/versioninfo/java
