Chart Tooltip in android
Indus Systems
Post by Indus Systems » Thu Feb 09, 2012 6:57 am
Can we show a tooltip on series touch event? Is there any callback function for series touch event?
Shibu
Indus Systems Inc
Re: Chart Tooltip in android
Post by Yeray » Thu Feb 09, 2012 10:24 am
Hi Shibu,
There is a Marks Tip tool as you can see in the Android demo. Isn't it what you are looking for?
Indus Systems
Post by Indus Systems » Thu Feb 09, 2012 12:39 pm
Hello, Yeray
Yes, That is we are looking.
With Thanks
Shibu
Indus Systems Inc
Indus Systems
Post by Indus Systems » Fri Feb 10, 2012 5:02 am
Hello Yeray,
It is not working when pan is enabled. Also is it possible to disable that toast, because we need only the touch event of the series
Shibu
Indus Systems Inc
Post by Yeray » Mon Feb 13, 2012 10:15 am
Hi Shibu,
The Pan is disabled by default. So I think only the Zoom could interfere here. You could disable it as follows:
tChart1.getZoom().setAllow(false);
Indus Systems
Post by Indus Systems » Mon Feb 13, 2012 11:33 am
Hello Yeray,
We use pan featur for our chart because we have to show large number of categories in chart. So it should pan chart area horizontally.
Shibu
Indus Systems Inc
Post by Yeray » Tue Feb 14, 2012 11:14 am
Hi Shibu,
Ah, I've found the Panning MouseButton should be BUTTON1 in Android. Otherwise it could give problems.
The following code and it seems to work fine for me here:
		ThemesList.applyTheme(tChart1.getChart(), 1);
		tChart1.getLegend().setVisible(false);
		Bar bar1 = new Bar(tChart1.getChart());
		bar1.fillSampleValues(30);
		tChart1.getAxes().getBottom().setMinMax(-0.5, 9.5);
		MarksTip mark1 = new MarksTip(tChart1.getChart());
		tChart1.getPanning().setMouseButton(FrameworkMouseEvent.BUTTON1);
		tChart1.getPanning().setAllow(ScrollMode.HORIZONTAL);
		mark1.setMouseAction(MarksTipMouseAction.CLICK);
