Flickering on IOS
Flickering on IOS
Then you select a series on IOS the chart is flickering.
Is it possible to avoid this?
Jørgen
Jørgen
Re: Flickering on IOS
Hi Jørgen,
Are you reproducing this in any of the examples of the demo?
Maybe in the testing example I posted here?
This sample flickers:
http://www.steema.com/files/public/teec ... g/test.htm
not always, try to click on the series in the legend.
Jørgen
Jørgen
Hi Jørgen,
Some enhancements have been done to TeeChart.js and we are not able to reproduce this issue here now. I'll send you the current version, can you please check if it solves the problem for you?
Now it doesn't flicker but it is not possible to select series with single tap
if you swipe over the series it is selected
Added sample chart
Added sample chart
- rr.zip
- (255.8 KiB) Downloaded 1744 times
Any updates?
Hi Jørgen,
this should be related with the focused html5 canvas element. In focus is not assigned, user have to tap over the object before to be able to swipe of tap over the chart Series.
The following code shows how to set a focus for specific elements :
<canvas id="camvas"
width="500px"
height="500px"
tabindex="1">
</canvas>
Pep Jorge
http://support.steema.com
Changed this
<BODY onload="draw()" onresize="resize()">
<br><canvas id="canvas" style="height:90%; width: 100%; align: center;" tabindex="1";>
</canvas>
</BODY>
but that did not help.
Must I do something else to make it work?
</canvas>
</BODY>
- rr.zip
- (1.58 KiB) Downloaded 1676 times
Any idea then you will release a version that woks better on IOS?
we're working on this version in order to improve its functionality, I've noticed that using zoom from a device does not work at all, due to the touch gestures, however, I can do a scroll at in this example (which I'm not sure if this is what you're trying to accomplish or just do a tap over the series pointer). Could you please check if it's working for you ?
You can also try to run this example which uses tap, but for the moment the tap it's not very accurate for use into the device.
Pep Jorge
Scroll sample is ok.
This doesn't work:
http://www.steema.com/files/public/teec ... aphics.htm
It is not possible to select a series.
This work if you move you finger to the pie instead of taping it.
http://www.steema.com/files/public/teec ... ltipie.htm
Jørgen
This doesn't work:
Jørgen
Hi Jørgen,
ok, we're working on these issues, gestures on devices.
We hope to have a new maintenance release available shortly.
Pep Jorge
