Export Gantt HTML5 JScript
Menant.D
Post by Menant.D » Wed Dec 21, 2016 11:12 am
the export of a gantt to HTML5 seems not working well.
TeechartHtml5Gantt.zip
(60.17 KiB) Downloaded 2031 times
Re: Export Gantt HTML5 JScript
Post by Yeray » Fri Dec 23, 2016 10:48 am
I've reproduced the problem so I've added it to the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=1727
Thanks for reporting it.
Menant.D
Post by Menant.D » Fri Dec 23, 2016 2:34 pm
thanks for your reply.
We look at the java script and we see that axes are inverted.
It seems not difficult to correct it. Do you think you could send us a patch?
It's very important for us, when do you think we can have a patch?
Post by Sandra » Tue Dec 27, 2016 12:37 pm
Hello Menant,
We aren't sure when you fix the problem. But, when we find a fix for it, we contact immediately with you.
Thanks in advance
Post by Marc » Fri Jul 07, 2017 3:37 pm
You can get a copy of the calculated Axis Increment before exporting the Chart.
Eg.
procedure TForm4.Button1Click(Sender: TObject);
var
  JavascriptExportFormat: TJavascriptExportFormat;
  inherited;
  Chart1.Axes.Bottom.Increment := Chart1.Axes.Bottom.CalcIncrement;
  JavascriptExportFormat            := TJavascriptExportFormat.Create;
  JavascriptExportFormat.Panel      := Chart1;
  JavascriptExportFormat.CanvasName := 'canvas' + intToStr(Tag);
  JavascriptExportFormat.JScript.SaveToFile('GanttTest.html');
The above code tests successfully with the example.
