Different pointer style on same series line
DALC.SENIOR
Post by DALC.SENIOR » Wed May 15, 2013 5:49 pm
Is there a way to assign different Pointer Styles to different points on the same series line, based on the values?
For example in Audiology I use a Circle for the pointer on a LinePoint series.
But sometimes a point will need to be a triangle if that value was masked.
Re: Different pointer style on same series line
Post by Yeray » Thu May 16, 2013 2:45 pm
As I said here I can only think on overriding the Pointer.draw function changing the style in it depending on the index.
Another alternative would be to use different series for different pointer styles.
DALC.SENIOR
Post by DALC.SENIOR » Tue May 21, 2013 4:53 pm
Thank you. Will keep trying.
