GANTT chart automatic reposition (TeeChart Pro 6.01)
GEINFOR
Post by GEINFOR » Thu Jun 05, 2008 4:43 pm
In a GANTT chart I have added the possibility to reposition and to resize the bars of the graphic with TGanttTool component, but I have two problems:
(1) If there are different bars/tasks of the GANTT chart connected among them, when I reposition or resize a bar, the other connected bars are not repositioned automatically. If I move a bar that represents a task to perform until its end finish after the start of the following task to perform, that the following tasks are not repositioned automatically to start just in the end of the prevoius task. This automatic repositioning is possible to perform with the component?
(2) I need to show a popup menu when press rightclick mouse button on a concrete bar. The problem is that, when select a menu item, the bar is repositioned while moves the mouse pointer, and it's necessary to click again to finish the repositioning.
I try to avoid this bad functionality deactivating drag and resize, but without success. I show you an example:
procedure TForm1.SerieGanttClick(Sender: TChartSeries; ValueIndex: Integer;
Button: TMouseButton; Shift: TShiftState; X, Y: Integer);
 if Button = mbRight then
  Gantt.AllowDrag := False;
  Gantt.AllowResize := False;
  Try
  PopupMenu.PopUp(X, Y + 100);
  Finally
   Gantt.AllowDrag := True;
   Gantt.AllowResize := True;
  End;
It is possible to deactivate this funcionality when show a popup menu and select an item without the repositioning problem?
Jose
Post by Yeray » Fri Jun 06, 2008 8:52 am
Hi Jose,
1) I think you should use OnDragBar and OnResizeBar events from your Gantt Tool to explore the whole Gantt series and modify start or end values when they are superposed. I think you should do something like following. But note that it's not completed, but maybe it's a good start.
procedure TForm1.ChartTool1ResizeBar(Sender: TGanttTool; GanttBar: Integer;
  BarPart: TGanttToolBarPart);
var i: Integer;
wide: Double;
  with Series1 do
      if (StartValues.Items[i] > StartValues.Items[GanttBar]) and (StartValues.Items[i] < EndValues.Items[GanttBar]) then
        wide := EndValues.Items[i] - StartValues.Items[i];
        StartValues.Items[i] := EndValues.Items[GanttBar];
        EndValues.Items[i] := StartValues.Items[i] + wide;
2) I've tried what you say and achieved it with OnClickSeries and OnMouseDown events. I think that your problem here was that the Gantt series started to drag/resize before disabling the functionalities.
procedure TForm1.Series1Click(Sender: TChartSeries; ValueIndex: Integer;
    ChartTool1.AllowDrag := True;
    ChartTool1.AllowResize := True;
procedure TForm1.Chart1MouseDown(Sender: TObject; Button: TMouseButton;
  if (Button = mbRight) and (Series1.Clicked(X,Y) >= 0) then
    ChartTool1.AllowDrag := False;
    ChartTool1.AllowResize := False;
    Try
      ShowMessage('okay');
    finally
GEINFOR
Post by GEINFOR » Fri Jun 06, 2008 11:36 am
Hi Yeray!
Point 2 is solved. Thanks!!!!
About point 1, I see that if reposition one bar, change all bars according init bar position. I think that the better way is to reposition all bars that depend on bar repositioned/resized when the user release the mouse button (in the mouse up event).
There are an easy way to access all bars that depends of one bar, and reposition recursively from one bar to forward?
Thanks in advance
Post by Narcís » Fri Jun 06, 2008 1:27 pm
Hi GEINFOR,
Yes, you can use NextTask property. You can find an eample using NextTask on this thread.
Hope this helps!
GEINFOR
Post by GEINFOR » Fri Jun 06, 2008 3:58 pm
Ok, Narcís. Moltes gràcies.
Jose
Post by Narcís » Mon Jun 09, 2008 7:08 am
Hola Jose,
De res! :wink:
