BCB 6 install error (TeeChart v7.01)
AlexW
Post by AlexW » Tue Aug 31, 2004 12:56 pm
:( Got the following message at 99% completion of installation. Nothing got installed, as far as I see. (Using BCB 6 professional under xP)
EXCEPTION:
Can't load package C:\Program Files\Steema Software\TeeChart 7 for C++ Builder 6\BuilderC6\Bin\DclTee7C6.bpl.
The system cannot find the file specified
I used all the defaults for file locations. What do I do ??
Alex
Post by Pep » Wed Sep 01, 2004 7:34 am
Hi Alex,
you're correct, we're aware of this. The only problem is the path in the installer is not correct (changed letter i.e. instead of CBuilder6 we use BuilderC6). A temporary solution is to manually add design time packages to BCB package list (can be done with couple of clicks) or create the folder manually before do the installation.
We'll fix this problem and post a new installers on our web site in the coming days.
