I am trying to install the dclTee8QR5D12.bpl package in Delphi2009, but when I compile it or try to install it from the project manager, I get the error "[DCC Fatal Error] Tee8QR5D12.dpk E2202: required package 'QR5RunD2008' not found". This comes from line 38 in package Tee8QR5D12, where QR5RunD2008 is in a "requires" declaration. I tried to rename it to QR5RunD2009, but that does not help.
I have QR5 running in the IDE and the TeeChart components show up fine in the Tool palette.
- Any ideas?
regards
Claus
dclTee8QR5D12.bpl installation problem
Re: dclTee8QR5D12.bpl installation problem
Hi Claus,
Have you followed the instructions from the QuickReport article here?
Please, try with the following packages that have been prepared some time ago:
- Tee8QR5D12 sources + compiled.zip
- (51.65 KiB) Downloaded 525 times
Hi Yearay,
I think I have it running now, but it is a long a weird installation procedure for a small component. You probably have some problems with automatic detection of the QR-versions running on the user's machine, but it would be nice, if the TQRChart just installed itself together with the rest of the TeeChart components after which, the user could change its properties to be compatible with the QR-version (s)he uses.
Claus
Claus
Hi Claus,
TeeChart installer already tries to do it but in some cases it fails. This is a known problem already in the wish list to be revised in future releases (TV52014532).
