tchart->onclickseries for tpointseries -> no action
Michael
Post by Michael » Wed Jul 28, 2010 5:59 am
I have installed the teechart pro 4.07 for delphi 2009 and the program of replacing standard-teecart for delphi.
I replaced all the old components by new and tested program. I use the onclick event to select a specific function, Unfortunately at tpointseries the onclick event does not fire. I use tlineseries, then the event also triggered it.
what is the problem? what should I do if my program is running again so as before? Or is this a bug?
I would be grateful if you could help me quickly.
Michael
Re: tchart->onclickseries for tpointseries -> no action
Post by Michael » Wed Jul 28, 2010 6:27 am
I again, I test very different curve types with the onclickevent. I now use a smooth tlineseries-chart. i need many attempts to trigger the event. too many.......
Post by Narcís » Wed Jul 28, 2010 8:43 am
Hi Michael,
I guess you mean 8.07 not 4.07 here, is that correct?
What about using TChart's OnClickSeries event? If the problem persists please attach a simple example project we can run "as-is" to reproduce the problem here.
Michael
Post by Michael » Wed Jul 28, 2010 10:21 am
hmmm... the version number of the tchart is called :"TeeChart pro v2010.00.00407 Win32". I downloaded it yesterday.
The problem occurs when 2d series on.
here is a little demo. I hope the errors can be understood within. Please click on the series and if successful, it then appears a window. ;-)
unit Unit2;
interface
uses
  Dialogs, TeEngine, Series, StdCtrls, ExtCtrls, TeeProcs, Chart;
type
  TForm2 = class(TForm)
    Chart1: TChart;
    Panel1: TPanel;
    Button1: TButton;
    CheckBox1: TCheckBox;
    procedure Chart1ClickSeries(Sender: TCustomChart; Series: TChartSeries;
      ValueIndex: Integer; Button: TMouseButton; Shift: TShiftState; X,
      Y: Integer);
    procedure CheckBox1Click(Sender: TObject);
  private
    { Private-Deklarationen }
  public
    { Public-Deklarationen }
var
  Form2: TForm2;
implementation
{$R *.dfm}
procedure TForm2.Button1Click(Sender: TObject);
 var p:Tpointseries;
     l: TLineSeries;
p:=Tpointseries.Create(Chart1);
l:=TLineSeries.Create(Chart1);
with chart1 do begin
View3D:=false;
LeftAxis.SetMinMax(0,21);
BottomAxis.Automatic:=true;
BottomAxis.labelsangle:=90;
BottomAxis.LabelsFont.Size:=9;
BottomAxis.LabelsOnAxis:=true;
BottomAxis.Title.Font.size:=14;
BottomAxis.Title.Font.Color:=clblue;
LeftAxis.LabelsAngle:=90;
LeftAxis.Title.Font.Color:=clblue;
LeftAxis.Title.Font.size:=14;
Title.Font.Size:=16;
AddSeries(p);
AddSeries(l);
p.AddXY(1,5);
p.AddXY(2,1);
p.AddXY(3,9);
p.AddXY(4,12);
p.AddXY(5,7);
l.AddXY(1,15);
l.AddXY(2,11);
l.AddXY(3,19);
l.AddXY(4,22);
l.AddXY(5,17);
procedure TForm2.Chart1ClickSeries(Sender: TCustomChart; Series: TChartSeries;
  ValueIndex: Integer; Button: TMouseButton; Shift: TShiftState; X, Y: Integer);
showmessage('Im a Clickevent');
procedure TForm2.CheckBox1Click(Sender: TObject);
if CheckBox1.State=cbUnchecked then Chart1.View3D:=false else Chart1.View3D:=true;
end.
And here the "dfm"
object Form2: TForm2
  Left = 0
  Top = 0
  Caption = 'Form2'
  ClientHeight = 479
  ClientWidth = 692
  Color = clBtnFace
  Font.Charset = DEFAULT_CHARSET
  Font.Color = clWindowText
  Font.Height = -11
  Font.Name = 'Tahoma'
  Font.Style = []
  OldCreateOrder = False
  PixelsPerInch = 96
  TextHeight = 13
  object Chart1: TChart
    Left = 0
    Top = 0
    Width = 692
    Height = 438
    BackWall.Brush.Gradient.Direction = gdBottomTop
    BackWall.Brush.Gradient.EndColor = clWhite
    BackWall.Brush.Gradient.StartColor = 15395562
    BackWall.Brush.Gradient.Visible = True
    BackWall.Gradient.Direction = gdBottomTop
    BackWall.Gradient.EndColor = clWhite
    BackWall.Gradient.StartColor = 15395562
    BackWall.Gradient.Visible = True
    BackWall.Transparent = False
    Foot.Font.Name = 'Verdana'
    Gradient.MidColor = 15395562
    LeftWall.Color = 14745599
    Legend.Font.Name = 'Verdana'
    Legend.MaxNumRows = 0
    RightWall.Color = 14745599
    SubFoot.Font.Name = 'Verdana'
    SubTitle.Font.Name = 'Verdana'
    Title.Text.Strings = (
      'TChart')
    OnClickSeries = Chart1ClickSeries
    BottomAxis.Axis.Color = 4210752
    BottomAxis.Grid.Color = 11119017
    BottomAxis.LabelsFont.Name = 'Verdana'
    BottomAxis.MaximumOffset = 5
    BottomAxis.MinimumOffset = 5
    BottomAxis.TicksInner.Color = 11119017
    BottomAxis.Title.Font.Name = 'Verdana'
    DepthAxis.Axis.Color = 4210752
    DepthAxis.Grid.Color = 11119017
    DepthAxis.LabelsFont.Name = 'Verdana'
    DepthAxis.TicksInner.Color = 11119017
    DepthAxis.Title.Font.Name = 'Verdana'
    DepthTopAxis.Axis.Color = 4210752
    DepthTopAxis.Grid.Color = 11119017
    DepthTopAxis.LabelsFont.Name = 'Verdana'
    DepthTopAxis.TicksInner.Color = 11119017
    DepthTopAxis.Title.Font.Name = 'Verdana'
    LeftAxis.Axis.Color = 4210752
    LeftAxis.Grid.Color = 11119017
    LeftAxis.LabelsFont.Name = 'Verdana'
    LeftAxis.MaximumOffset = 5
    LeftAxis.MinimumOffset = 5
    LeftAxis.TicksInner.Color = 11119017
    LeftAxis.Title.Font.Name = 'Verdana'
    RightAxis.Axis.Color = 4210752
    RightAxis.Grid.Color = 11119017
    RightAxis.LabelsFont.Name = 'Verdana'
    RightAxis.TicksInner.Color = 11119017
    RightAxis.Title.Font.Name = 'Verdana'
    Align = alClient
    TabOrder = 0
    ExplicitTop = 2
    ColorPaletteIndex = 13
  end
  object Panel1: TPanel
    Left = 0
    Top = 438
    Width = 692
    Height = 41
    Align = alBottom
    Caption = 'Panel1'
    TabOrder = 1
    ExplicitLeft = 508
    ExplicitTop = 444
    ExplicitWidth = 185
    object Button1: TButton
      Left = 300
      Top = 8
      Width = 75
      Height = 25
      Caption = 'Init'
      TabOrder = 0
      OnClick = Button1Click
    end
    object CheckBox1: TCheckBox
      Left = 460
      Top = 12
      Width = 97
      Height = 17
      Caption = '3D'
      TabOrder = 1
      OnClick = CheckBox1Click
    end
  end
end
Michael
Post by Michael » Thu Jul 29, 2010 8:20 am
they could reproduce the errors with the clickseriesevent already? Or they need more information?
regards
Post by Yeray » Thu Jul 29, 2010 9:42 am
Hi Michael,
You are right. For some reason the Chart event OnClickSeries doesn't seem to work with TPointSeries. I've added it to the defect list to be fixed in future releases (TV52015058).
However, you could try with the OnMouseDown event:
procedure TForm1.Chart1MouseDown(Sender: TObject; Button: TMouseButton;
  var i: Integer;
    if (Chart1[i].Clicked(X,Y) > -1) then
      showmessage('MouseDown event, series clicked: ' + IntToStr(i));
sajtab
Post by sajtab » Fri Oct 22, 2010 12:17 am
I have also seen a similar problem with TLineSeries when the series is a straight horizontal line. I am using TeeChart Standard V9, 2010.
Sajjad
Post by Narcís » Fri Oct 22, 2010 3:04 pm
Hello Michael and Sajjad,
Both issues works fine for me here using our latest sources and code snippet below. Are you using v2010.01.11004 which is the latest version available at the client area?
uses Series;
procedure TForm1.Chart1ClickSeries(Sender: TCustomChart;
  Series: TChartSeries; ValueIndex: Integer; Button: TMouseButton;
  ShowMessage('Series clicked');
  Chart1.View3D:=False;
//  Chart1.AddSeries(TPointSeries.Create(Self));
  Chart1.AddSeries(TLineSeries.Create(Self));
  Chart1[0].Add(10);
  Chart1[0].Add(10);
sajtab
Post by sajtab » Fri Oct 22, 2010 5:20 pm
Hi Narcis,
I have been using TeeChart Standard v2010.00.00407 and haven't tried the latest.
Sajjad
Post by Narcís » Mon Oct 25, 2010 7:05 am
Hi Sajjad,
Can you please try if latest release solves the issue at your end?
