TMarksTipTool problems when 3D is enabled
mLapido
Post by mLapido » Thu Oct 14, 2004 2:45 pm
whenever 3D is enabled the TMarksTipTool does not work properly. It seems that it's mapping for hit test remains unchanged (i.e. sticks to the 2D plotting of the chart). As result it seems to be "crazy" as the user moves the mouse over the chart it would show the tooltips but the values don't acctually refer to what's under the mouse, the value showing on the tooltip is the one of the data that would be under the mouse on the 2D version.
Post by Pep » Thu Oct 14, 2004 3:17 pm
which TeeChart Pro version are you using ?
Could you please post an example into the steema.public.attachments newsgroup with which I can reproduce the problem "as is" here ?
mLapido
Post by mLapido » Thu Oct 14, 2004 3:36 pm
I'm using the TeeChart v. 7.0.
I don't have an example that I can post right now, this problem is occuring in several instances of the control in a large system, but in a few hours I'll develop one and post it.
mLapido
Post by mLapido » Fri Oct 15, 2004 4:05 pm
I tried to post the example at steema.public.attachments but this url is not being found.
Please give directions of how to send you the example.
regards,
Milton Lapido
Post by Pep » Fri Oct 15, 2004 4:14 pm
Hi Milton,
you can access directly through news://berneda.com
mLapido
Post by mLapido » Fri Oct 15, 2004 5:30 pm
still no success. When I try to access the news://berneda.com I get a "server not found" message.
The zip file is quite small (500K) can I send it to your e-mail?
regards,
Milton Lapido
Post by Pep » Thu Oct 21, 2004 6:18 am
yes please, sent it directly to my acount pep@steema.com
mLapido
Post by mLapido » Thu Oct 21, 2004 12:50 pm
Fortunately,
one of the 25 infrastructure specialist in the company managed to solve the newsgroup access problem from my machine. :-)
I have posted the demo application that demonstrates this problem and the ones in the following posts:
- 3D chart sometimes doesn't fit in view. - mLapido - Fri Oct 15, 2004 6:41 pm
- Pie chart problems - mLapido - Fri Oct 15, 2004 5:30 pm
Best regards,
Milton Lapido
Post by Pep » Fri Oct 29, 2004 4:01 pm
Hi Milton,
see my other post about this problems.
