axis increment
Jennifer Good
axis increment
Post by Jennifer Good » Sat Dec 11, 2004 9:24 pm
we want to write code that will put axis labels at defined increments. what we tried was:
chart1.leftaxis.increment:=5;
and this does not seem to work. The increment changes fine in the charteditor, but not in code.
Natalie
Post by Pep » Mon Dec 13, 2004 7:04 am
Hi Natalie,
setting the increment as you've done should work fine, but maybe the problem is that there's not enought space to display all the labels. In case you want to display a specific labels the best way is to add custom axis labels. You can see one example which shows how to do this in the TeeChart Pro Demo features project.
