bar series width settings
Cyionics
Post by Cyionics » Mon Dec 27, 2004 6:33 pm
Is it possible to set the width of a bar series automatically so that they don't overlap, if not how can the %BarWidth be calculated based on the zoom level or other parameter?
Nominally I normally set this to 70% but in some cases bars are too wide when zoomed out and overlap.
Rgds
Peter
[/img]
Post by Pep » Mon Dec 27, 2004 11:00 pm
Hi Peter,
in which cases ? Setting the BarWidthPercent to any value should keep the spaces between the bars. How can I reproduce the result you're getting ?
Cyionics
sample overlapping file
Post by Cyionics » Tue Dec 28, 2004 9:46 am
I've exported a .tee file to
http://www.cyionics.com/cyionics.tee
Rgds
Peter
Post by Pep » Tue Dec 28, 2004 10:14 am
Hi Peter,
ok, but which code you're using to get this result ?
Cyionics
bar width code
Post by Cyionics » Tue Dec 28, 2004 10:24 am
Hi This is the code used to create the chart
procedure TStudy.Plot(Chart: TChart);
var i : integer; Series: TBarSeries;
Chart.SeriesList.Clear;
Chart.ApplyZOrder := true;
for i := count-1 downto 0 do
Series := TBarSeries.Create (Chart);
if count=1
then Series.Title := self.Title
else Series.Title := Items.Title;
Chart.AddSeries (Series);
Series.MultiBar := mbNone;
Series.Marks.Visible := false;
Items.Plot (Series);
Cyionics
fix
Post by Cyionics » Thu Dec 30, 2004 9:31 am
I found the problem was cured by setting the autobarwidth to true
Series.AutoBarSize := True;
Rgds
Peter :D
Post by Pep » Thu Dec 30, 2004 9:33 am
Hi Peter,
great ! Thanks for the advise. :wink:
