Debugger Crashes with installed TeeChartPro
Wafios
Post by Wafios » Thu Jul 05, 2012 1:21 pm
Since I installed TeeChartPro-components in the IDE i always get Debugger crashes when I try to launch the debugger the second time.
Sometimes the ide crashes without any exception and somtimes the application under debugger control stops working on start up.
Is there any known problem?
What can I do there?
Thank you!
Re: Debugger Crashes with installed TeeChartPro
Post by Narcís » Thu Jul 05, 2012 1:38 pm
Hi Wafios,
Which exact IDE and TeeChart versions are you using? Do you get any specific error message?
Wafios
Post by Wafios » Thu Jul 05, 2012 2:43 pm
We use XE2 Update 4 Hotfix 1 with the the release from 2011/11/02.
Until Update 3 there was an exception "ntdll.dll" with Update 4 and Hotfix 1 there is no exception anymore, but suddenly the ide is gone and the desktop is shown!
Thank you for your quick reply.
Post by Yeray » Thu Jul 05, 2012 2:56 pm
Hi Wafios,
I see you are a source code customer.
Have you recompiled the TeeChart sources with TeeRecompile tool after upgrading to XE2 Update 4 Hotfix 1?
I'd also suggest you to download the latest version, TeeChart v2012.06 (13th June 2012).
Wafios
Post by Wafios » Thu Jul 05, 2012 3:59 pm
OK!
Do I still have to recompile TeeChart with Update 4 HF1 even when I download the latest version?
Post by Yeray » Fri Jul 06, 2012 7:29 am
Hi Wafios,
The source code version has always to be recompiled. It only includes the sources and no compiled file.
The binary versions don't include the sources. They include the compiled packages, compiled with each IDE up to that binary installer publishing date.
The latest binary version for XE2, v2012.06, was compiled with Update 4 Hotfix 1.
Wafios
Post by Wafios » Fri Jul 06, 2012 10:33 am
Thank you!
We currently use the binary installer.
Post by Yeray » Fri Jul 06, 2012 11:09 am
Hi Wafios,
Is the problem still reproducible or is it solved now?
Wafios
Post by Wafios » Fri Jul 06, 2012 12:31 pm
Until now there is no crash happend anymore...
Thank you!
Post by Yeray » Fri Jul 06, 2012 3:28 pm
Great, Wafios!
You're welcome!
