MatsOle
Post
by MatsOle » Mon Mar 13, 2017 4:33 pm
I want to set parameters to a TPoint3DSeries so that only the n latest points in the series are drawn.
I have tried to use the following code in the procedure Chart1BeforeDrawSeries(Sender: TObject);
if Form1.Series6.LastValueIndex > PointsToDraw
then StartIndex:=Form1.Series6.LastValueIndex - PointsToDraw
else StartIndex:=0;
Form1.Series6.DrawSeriesForward(StartIndex);
This is not working.
How is it done?
Post
by Yeray » Tue Mar 14, 2017 10:51 am
I see three alternatives depending on your setup:
- If the points are x-ordered you can just set the bottom axis with SetMinMax.
- If you aren't going to show the first points later, you can just remove the unwanted points.
- You could set as nulls the point that you don't want to be shown.
MatsOle
Post
by MatsOle » Tue Mar 14, 2017 10:58 am
My points are time-ordered, ie I want to draw them in the order they arrive.
I want to show the first points later.
How do I set a point to null?
Is it possible to reset a point to its original value after it has been set to null?
Post
by Yeray » Tue Mar 14, 2017 11:39 am
You can set a null point as follows:
This action sets its color to transparent so it won't be drawn. Later, you can set it visible again and the value is preserved:
Series1.SetNull(ValueIndex, False);
MatsOle
Post
by MatsOle » Tue Mar 14, 2017 1:22 pm
This works but have a drawback in that when you try to zoom in with a zoom rectangle
and hit a point that is invisible the zoom rectangle is not shown.
When setting Series6.Visible:=false, which hides the complete series, the zooming works fine.
Is it possible to set Visible:=false on individual points to avoid the zoom problem?
Post
by Yeray » Wed Mar 15, 2017 7:52 am
Another alternative would be to inherit TPoint3DSeries to add an array of booleans (ie VisiblePointer) to control the visibility of the individual points
using OnGetPointerStyle event or
overriding DrawPointer.
Post
by Yeray » Wed Mar 15, 2017 8:08 am
For
TPoint3DSeries the second technique should be a bit different. Here an example:
uses Series, TeePoin3;
type
TMyPoint3DSeries = class(TPoint3DSeries)
protected
Procedure DrawValue(ValueIndex:Integer); override;
public
VisiblePointer: array of Boolean;
Procedure TMyPoint3DSeries.DrawValue(ValueIndex:Integer);
Pointer.Visible:=VisiblePointer[ValueIndex];
inherited;
var i, j: Integer;
Chart1.Legend.Alignment:=laBottom;
for i := 0 to 2 do
with Chart1.AddSeries(TMyPoint3DSeries) as TMyPoint3DSeries do
FillSampleValues(1000);
LinePen.Visible:=False;
UseColorRange:=False;
SetLength(VisiblePointer,Count);
for j:=0 to Count-1 do
VisiblePointer[j]:=j mod 200=0;
