TeeChart 2017 and QuickReport6
Jorsoft
Post by Jorsoft » Thu Mar 22, 2018 9:51 am
I have installed the new TeeChart 2017, but now I get an error and cannot use TeeChart for QuickReport6.
The exact error is :
Can't load package C:\Program Files (x86)\Steema Software\Steema TeeChart Pro VCL FMX Source Code 2017.23\Source\..\Compiled\Delphi25.win32\Bin\DclTeePro925.bpl.
Cannot load package 'QRWRunDXE10_1_w64.' It contains unit 'QRPageInfo', which is also contained in package 'QRWRunDXE10_2_w64'.
I have uninstalled and reinstalled both TeeChart and QuickReport, both the error remains.
My TeeChart version is TeeChartVCLFMXSOURCE-2017.23 and the QuickReport version is QR6DXE10_2_Tokyo (both the latest version).
Is there a fix and/or solution for this?
Re: TeeChart 2017 and QuickReport6
Post by Yeray » Fri Mar 23, 2018 1:51 pm
Are you using the packages here?
Note you'll have to rebuild them before installing the bpls.
Jorsoft
Post by Jorsoft » Mon Mar 26, 2018 1:35 pm
Thank you for the package, I have downloaded and build them, but I get the error
Can't load package C:\Users\1018001\Downloads\Tee9QR6D25\compiled\Bpl\win32\DclTee9QR6D25.bpl.
The specified module could not be found.
The bpl files do exists in that location however. I have build both the projects and I have tried to install the package via the project itself (rightmouse button / Install).
But also via de Install packages option via the menu. Both are returning this error.
Am I missing a step?
Kind regards,
Bart
Post by Yeray » Tue Mar 27, 2018 1:43 pm
Hello Bart,
Please check you have high privileges running the IDE "as administrator"
