How to reset Tchart in runtime?
Sciensoria
Post by Sciensoria » Fri May 26, 2023 10:45 am
Dear Tchart support team members,
I am using Tchart to plot data received over a USB link.
I would like to inform you that the chart is currently blocked after receiving a very large floating-point number. The error message displayed is 'floating point operation error'.
Could you advise me on how to resolve this issue without requiring a program restart, preferably with a runtime solution?
Thank you in advance
Re: How to reset Tchart in runtime?
Post by Yeray » Mon May 29, 2023 6:23 am
Could you please give us more information?
What TeeChart version are you using? Can you please arrange a simple example project we can run as-is to reproduce the problem here?
Sciensoria
Post by Sciensoria » Mon Dec 18, 2023 6:17 pm
Dear Yeray,
Thank you for your reply.
Very sorry for my late reply. I had issues with my mailbox and lost a lot of emails.
The version of my Tchart is TeeChart Pro v2012/16 VCL.
I managed to eliminate error during the receive process, so my Tchart runs smoothly now. However, I still don't know how to reset a chart after a floating point error in order to get it working again.
Best regards
Post by Yeray » Mon Dec 18, 2023 8:34 pm
If you want to prevent the error from happening, we'd need more info to try to reproduce the problem here, preferably a simple example project.
If you just want to remove the a point that has been added to a series, you can remove the point with the Delete(ValueIndex: Integer) function.
Or you can Clear the series or even ClearChart if you want to be more drastic.
