Pie Chart Legend bug or my missing call?
JNuzzi
Post by JNuzzi » Mon Jun 16, 2025 7:26 pm
I am using a Pie Chart and when I send some data to it the first time, it is great. It looks like:
However, when I try to limit the data, the legend entries all stay. I call the Clear function on the series, then run the data again with fewer entries and get:
Thank you,
John
Re: Pie Chart Legend bug or my missing call?
Post by Yeray » Tue Jun 17, 2025 2:49 pm
Hello John,
I've seen the fix for #1210 in TeeChart v2025.44 breaks this.
We are revising it.
JNuzzi
Post by JNuzzi » Tue Jun 17, 2025 5:54 pm
Thanks Yerah.
I think I have identified another small bug. Using PrintPartialCanvas, the chart titles don't seem to adjust to the given rectangle:
I was going to go tinkering around in the code, but figured I would point it out anyway.
John
JNuzzi
Post by JNuzzi » Tue Jun 17, 2025 5:57 pm
Plus, what does PrintProportional do? It says it is on by default, but the charts seem to stretch if I don't set the right aspect ratio. The circular gauges ignore the Circled property.
Thanks again...
JNuzzi
Post by JNuzzi » Tue Jun 17, 2025 6:36 pm
I figured maybe I could get around it by drawing to a Bitmap, then painting that to the printer. I got this:
John
Post by Yeray » Tue Jun 17, 2025 8:12 pm
Hello John,
We are revising it.
I came up with this fix:
--- a/Chart.pas
+++ b/Chart.pas
@@ -418,6 +418,7 @@ type
     ILegend : TCustomChartLegend;
+    procedure FontChanged(Sender: TObject);
     function GetFont:TTeeFont;
     procedure SetAlign(const Value:TCanvasTextAlign);
     procedure SetCustom(SetPos:Boolean);
@@ -5400,6 +5401,11 @@ begin
   result:=Assigned(FFont);
+procedure TLegendItem.FontChanged(Sender: TObject);
+begin
+  SetCustom(False);
+end;
 function TLegendItem.GetFont:TTeeFont;
 var Old : Boolean;
@@ -5417,6 +5423,7 @@ begin
         FFont:=TTeeFont.Create(nil);
+  FFont.OnChange:=FontChanged;
   result:=FFont;
@@ -5516,11 +5523,6 @@ begin
     result:=TLegendItem.Create;
     result.ILegend:=ILegend;
-    if ILegend.InternalLegendStyle=lsAuto then
-       ILegend.CalcLegendStyle;
-    result.Text:=ILegend.FormattedLegend(Index);
     inherited Items[Index]:=result;
JNuzzi
Post by JNuzzi » Wed Jun 18, 2025 2:51 am
Hello, I am getting a compile error with those changes:
John
Post by Yeray » Wed Jun 18, 2025 8:29 am
Hello John,
Sorry. This is the fix for that error:
--- a/Chart.pas
+++ b/Chart.pas
@@ -5523,6 +5523,9 @@ end;
   SetCustom(False);
+  if Assigned(ILegend) then
+    ILegend.CanvasChanged(Sender);
@@ -5542,7 +5545,12 @@ begin
+  {$IFDEF FMX}
+  FFont.Brush.OnChanged:=FontChanged;
+  {$ELSE}
+  {$ENDIF}
   result:=FFont;
JNuzzi
Post by JNuzzi » Wed Jun 18, 2025 1:41 pm
Hello Yeray,
Thank you. It compiles now, and the legends work as intended.
I have another new issue (besides titles and stretching during printing), now it just stops when printing the charts (or takes a really long time...not sure):
John
JNuzzi
Post by JNuzzi » Wed Jun 18, 2025 1:43 pm
It did eventually print after a few minutes.
Post by Yeray » Wed Jun 18, 2025 3:15 pm
I'm not sure to understand the problems you are experiencing with printing.
JNuzzi
Post by JNuzzi » Wed Jun 18, 2025 4:34 pm
Sure. Here is a quick little program:
(btw, the title was set to left justified alignment)
Here is a PDF print of that:
The Sample Project Zip is attached.
It's giving me all types of hell. I just compiled a Release version and lost the center alignment on the circular gauges. it works with Debug still, though.
John
SamplePrintError.zip
(9.96 KiB) Downloaded 324 times
JNuzzi
Post by JNuzzi » Wed Jun 18, 2025 4:36 pm
It seems like using anything but the default center alignment for the title does odd stuff.
JNuzzi
Post by JNuzzi » Thu Jun 19, 2025 4:53 pm
I have another printing issue that I would like to resolve if possible. The pie chart really stretches and the margins look way bigger.
Here is the pie chart on the screen:
And here it is printed to PDF:
I am using the ChartPrintRect and the aspect ratios of screen vs print rect are the same, but it always squishes the image.
John
JNuzzi
Post by JNuzzi » Mon Jun 23, 2025 12:55 pm
