Bar3DSeries UseYOrigin False behavior
SteveP
Post by SteveP » Wed May 18, 2005 8:20 pm
Bar3DSeries.UseYOrigin := false causes all bars to be drawn with their individual minimums set to the overall minimum of all bars. This causes all bars to be drawn down to the bottom axis. They no longer span just the range from their Y to Offset values. The Y axis minimum becomes the overall minimum of all bars.
Is this the designed behavior ? Could it instead keep displaying all bars over their Y to Offset range but only adjust the Y axis minimum to the overall minimum of all bars ? The Y axis acts this way. It autoscales to whatever the overall maximum of all bars is.
Post by Narcís » Thu May 19, 2005 7:33 am
Hi Steve,
The problem is you are not setting YOrigin for the series and its default value is zero. You should do something like:
  Series1.AddBar(1,4,2);
  Series1.YOrigin:=2;
  Series1.UseYOrigin:=true;
SteveP
Post by SteveP » Thu May 19, 2005 1:05 pm
Narcis,
Setting YOrigin for the series basically means having to set the minimum value for the series. Typically, one does not have to set the series minimum. The chart does that automatically by itself. It just seemed to me that there could be consistant behavior if the Bar3D series could also determine the overall series minimum value, like it does with its overall maximum value.
Steve
Post by Pep » Thu May 26, 2005 11:04 am
Hi Steve,
This is as designed, but you can always calculate the desired YOrigin and asign it in the OnAfterDraw event :
Series1.YOrigin := Series1.MinYValue;
Series1.UseYOrigin := true;
