Change Series at Runtime
kev
Post by kev » Fri Jul 29, 2005 2:07 pm
Is there a way to change a FastLine Series into a LineSeries and back at runtime? I can do this executing the ChartEditor at runtime and it works fine. I would like to just make a user checked option for this. Why do I want to do this? Because I am doing high speed multichannel Data Acquisition which works very well using FastLine. However, I would like to see my sample density after the chart has been populated. This can be seen perfectly with Series Points turned on which is not available in FastLine. It seems to me that if I can do this through the ChartEditor, I should be able to do it programatically.
Kev
Post by Narcís » Fri Jul 29, 2005 2:22 pm
Hi Kev,
Yes, you can do that using something like:
var tmp: TChartSeries;
  tmp := Chart1[0];
  ChangeSeriesType(tmp,TFastLineSeries);
kev
Post by kev » Fri Jul 29, 2005 2:43 pm
Yes I saw that, but...
I am using TChart 7Pro for Builder 6. I saw a couple of examples on the newsgroups, but they are for Delphi and I so far have not been able to figure out how to convert to C++.
thanks,
Kev
kev
Change Series at Runtime (Builder)
Post by kev » Mon Aug 01, 2005 4:25 pm
Anyone want to take a stab at this one? See the previous post.
thanks,
kev
Post by Pep » Tue Aug 02, 2005 11:29 am
Hi Kev,
you can do :
TChartSeries *ser;
ser = Series1;
ChangeSeriesType(ser,__classid(TPointSeries));
kev
Change Series at Runtime Builder
Post by kev » Tue Aug 02, 2005 7:16 pm
I must have tried every other "cast" besides that one. It works fine.
Kev
