Visual invalidation
mc
Visual invalidation
Post by mc » Tue Aug 09, 2005 2:52 pm
I am looking for a way to indicate that a chart has become invalid. Something like casting a gray shadow over the whole panel, including the series, would be good.
Post by Pep » Wed Aug 10, 2005 2:02 pm
you could change the aspect of the Chart to GrayScale, using the following code :
uses TeCanvas;
  if CheckBox1.Checked then { do gray scale... }
     TeeGrayScale( (Chart1.Canvas as TTeeCanvas3D).Bitmap,
                   false,
                   0);
procedure TForm1.CheckBox1Click(Sender: TObject);
Chart1.Enabled := not checkbox1.Checked;
Chart1.Repaint;
mc
Visual invalidation
Post by mc » Thu Aug 11, 2005 1:52 am
Thannk you. I had been using the Lighting tool, but this is another option.
I looked up TeeGrayScale in the help, but I don't understand the Amethod parameter. When I switched from 0 to 1, I saw no change.
Post by Pep » Thu Aug 11, 2005 6:32 am
yes, it's used to change the Method (linear or human eye), it's much similar, you can see the difference in the sample which can be found in the Demo Features project, do a search for "Gray Scale".
