Initial position of TCursorTool
PoLabs
Post by PoLabs » Wed Jul 15, 2009 7:34 am
I have a 2D chart with 2 vertical cursors which are by default positioned in center of my graph. How can I move them to initil position that differe from center.
eg. I would like to position cursor 1 to the left on chart and cursor 2 to the right. I saw you could set XValue or YValue bur what if my series had more than one same YValue or XValue?
Thank you in advance.
Best regards.
Re: Initial position of TCursorTool
Post by Yeray » Wed Jul 15, 2009 8:28 am
Hi PoLabs,
Please, take a look at the following example. Everything seems to work as expected:
uses series, TeeTools;
var series1: TPointSeries;
    i: Integer;
    cursor1, cursor2: TCursorTool;
  Chart1.View3D := false;
  series1 := TPointSeries.Create(self);
  Chart1.AddSeries(series1);
  for i:=0 to 25 do
    series1.AddXY(i, round(random*10));
  for i:=0 to 25 do
  cursor1 := TCursorTool.Create(self);
  cursor2 := TCursorTool.Create(self);
  Chart1.Tools.Add(cursor1);
  Chart1.Tools.Add(cursor2);
  cursor1.Style := cssVertical;
  cursor2.Style := cssVertical;
  cursor1.Pen.Color := clRed;
  cursor2.Pen.Color := clGreen;
  Chart1.Draw;
  cursor1.XValue := series1.XValues.MinValue;
  cursor2.XValue := series1.XValues.MaxValue;
If there is any important step I missed, please post here a code (or attach a simple example project) we can run as-is to reproduce the problem here.
PoLabs
Post by PoLabs » Wed Jul 15, 2009 8:41 am
Dummy me!! I am so deep into it so I just need to step on step back to see the solution. :oops:
Thank you very much.
Best regards.
PoLabs
Post by PoLabs » Wed Jul 15, 2009 9:50 am
One more question. :oops:
What if TCursorTool doesn't have assigned series property? Is still possible to set position of cursor?
I am using one cursor (general on chart) for several series, so I never really need one series to be assigned to cursor and I still would like to set it's position. Is that possible? I assume tha position could be only set if series is assigned to TCursorTool.
BR
Post by Yeray » Wed Jul 15, 2009 12:05 pm
Hi BR,
In the example I posted above I used two cursor tools without linking them to any series. I only used a series to obtain the left and the right values. You can also use the axis if you want:
  cursor1.XValue := Chart1.Axes.Bottom.Minimum;
  cursor2.XValue := Chart1.Axes.Bottom.Maximum;
PoLabs
Post by PoLabs » Wed Jul 15, 2009 12:12 pm
Thank you very much. It works! :)
Best regards,
Aljosa
PoLabs
Post by PoLabs » Wed Jul 15, 2009 1:06 pm
Again me... :oops:
I have some TLabel objects which I would like to move along with cursors. It is not problem to do that while moving cursor (i use onchange event), but how can I do that programaticly to set labels at cursor position?
an eg.
Label1.Left := GetCoordsFromvalue(Cursor.XValue)
What should be that GetCoordsFromvalue function?
Post by Yeray » Wed Jul 15, 2009 2:41 pm
Hi BR,
This is the one:
tChart1.Axes.Bottom.CalcXPosValue();
PoLabs wrote:Again me... :oops:
Don't worry. We are here for that!
PoLabs
Post by PoLabs » Wed Jul 15, 2009 7:15 pm
thanks for your answer. Your support is realy good.
When I try to use Chart.Axes.Bottom.CalcPos... but on runtime I get for every point 0. My axis min is -5 and max is +5. I set cursor C1 to left (-5) and C2 to right (5) and that works fine. When I try to move coresponding label (labels marks cursor like an eg. 'C1', 'C2') I would need coords to set properties Left and Top. I tried it with Label1.Left := Chart.Axes.Bottom.CalcPosFromValue(Chart.Axes.Bottom.Minimum), but if I inspect that property I alwys get 0 on runtime.
Well if there exist any answer to that I would very happy in other case I will just ignore it and remove labels and forget about it. Don't want to loose time on pretty small thing.
Thank you again.
Aljosa
Post by Yeray » Thu Jul 16, 2009 10:48 am
If I understand well you simply need to assign the new label X position at OnChartToolChange event. Here is a complete example using annotation tool instead of labels:
uses series;
var cursor1, cursor2: TCursorTool;
    annot1, annot2: TAnnotationTool;
    i: Integer;
  for i:=0 to 25 do
  for i:=0 to 25 do
  annot1 := TAnnotationTool.Create(self);
  annot2 := TAnnotationTool.Create(self);
  Chart1.Tools.Add(annot1);
  Chart1.Tools.Add(annot2);
  annot1.Text := 'Q1';
  annot2.Text := 'Q2';
  annot1.Shape.Color := cursor1.Pen.Color;
  annot2.Shape.Color := cursor2.Pen.Color;
  annot1.Shape.Transparency := 50;
  annot2.Shape.Transparency := 50;
  annot1.Shape.Shadow.Visible := false;
  annot2.Shape.Shadow.Visible := false;
  cursor1.OnChange := ChartTool1Change;
  cursor2.OnChange := ChartTool2Change;
  Chart1.Draw;
  annot1.Top := Chart1.ChartRect.Top;
  annot2.Top := Chart1.ChartRect.Top;
procedure TForm1.ChartTool1Change(Sender: TCursorTool; x, y: Integer;
  const XValue, YValue: Double; Series: TChartSeries; ValueIndex: Integer);
  annot1.Left := x;
procedure TForm1.ChartTool2Change(Sender: TCursorTool; x, y: Integer;
  annot2.Left := x;
PoLabs
Post by PoLabs » Fri Jul 17, 2009 10:34 am
thank you very much. It realy helped me a lot. I am very grateful for help.
I have another question. When I move cursor I have XValue of it. How can I get YValue of some series according to XValue of cursor. Now I am trying with
Ycoord := Series.CalcYPosValue(Cursor.XValue); // get y coord of XValue of cursor
Result := Series.YScreenToValue(Ycoord);
but it doesn't seem to be ok, values are different than expected. What am I doing wrong?
Aljosa
Post by Yeray » Fri Jul 17, 2009 11:18 am
Hi PoLabs,
Please, take a look at the interpolation example that Narcís posted here
PoLabs
Post by PoLabs » Tue Jul 21, 2009 11:27 am
I would like to thank you for your help. I solved problems with your and Narcis help.
Thanks again.
Best regards.
