Install TeeChart on Windows Seven, BIG trouble
arthemy
Post by arthemy » Mon Oct 05, 2009 11:53 am
I try install TeeChart 7.12 component in Windows 7, but receive exception in TeeRecompile.exe log:
Compilation started: 05.10.2009 15:35:51
Delphi v7 Enterprise
Tee77
Borland Delphi Version 15.0
Copyright (c) 1983,2002 Borland Software Corporation
46540 lines, 0.20 seconds, 339284 bytes code, 3141 bytes data.
TeeUI77
37705 lines, 0.36 seconds, 217544 bytes code, 905 bytes data.
TeeDB77
5457 lines, 0.09 seconds, 43112 bytes code, 197 bytes data.
TeePro77
78191 lines, 0.70 seconds, 467896 bytes code, 4033 bytes data.
TeeGL77
11052 lines, 0.11 seconds, 69900 bytes code, 2993 bytes data.
TeeImage77
22984 lines, 0.14 seconds, 147168 bytes code, 11301 bytes data.
TeeLanguage77
58055 lines, 0.45 seconds, 1156860 bytes code, 2405 bytes data.
DclTee77
3882 lines, 0.12 seconds, 31608 bytes code, 249 bytes data.
DclTeePro77
2163 lines, 0.16 seconds, 19660 bytes code, 213 bytes data.
DclTGL77
378 lines, 0.09 seconds, 4616 bytes code, 121 bytes data.
TeeQR77
675 lines, 0.08 seconds, 10276 bytes code, 117 bytes data.
DclTQR77
394 lines, 0.12 seconds, 7232 bytes code, 125 bytes data.
DclTeeStd77
3879 lines, 0.11 seconds, 26056 bytes code, 229 bytes data.
DclTeeProStd77
2162 lines, 0.14 seconds, 19036 bytes code, 213 bytes data.
TeeChart Installation
VERSION: 7
EXCEPTION:
Cannot delete registry value: $(DELPHI)\Bin\dcltee70.bpl
Error Code: 5 Description: Отказано в доступе
EXCEPTION:
Operation aborted
--------------------------------------------0.09 seconds, 43112 bytes code, 197 bytes data.
Re: Install TeeChart on Windows Seven, BIG trouble
Post by Yeray » Mon Oct 05, 2009 12:39 pm
Hi arthemy,
arthemy wrote:Cannot delete registry value: $(DELPHI)\Bin\dcltee70.bpl
Is is possible that the user you logged in with, hasn't rights to write in the windows registry?
Try to "Run as Administrator" the TeeRecompile tool.
