SeriesTextSource doesn't have DecimalSeparator in 8.04
timhamel
Post by timhamel » Wed Oct 21, 2009 6:43 am
Hi!
I am trying to use the SeriesTextSource component (version 8.04). Following your Importing text data from .Dat or .TXT files document.
The property DecimalSeparator seems to be not available in 8.04, but would be important for us since we are writing out the file with "." even
on systems with locale settings ","... How does the component work now? Does it use locale setting to determine the decimal separator? If yes, how can we force it to use "."?
Br, Tim
Re: SeriesTextSource doesn't have DecimalSeparator in 8.04
Post by Yeray » Wed Oct 21, 2009 8:05 am
Hi Tim,
What SO and IDE are you using? I think that this should work on any Windows and any delphi IDE:
  DecimalSeparator:='.';
  SeriesTextSource1.FieldSeparator:='/';
timhamel
Post by timhamel » Wed Oct 21, 2009 8:25 am
You are correct. For some reason I was checking this in the class because the example code
was showing:
With SeriesTextSource1 do
Fields.Clear;
AddField('X',1);
AddField('Y',2);
FieldSeparator := ' ';
DecimalSeparator := '.';
FileName := 'test.dat';
Series := Series1;
Active := True;
Br, Tim
Post by Yeray » Wed Oct 21, 2009 8:36 am
Hi Tim,
I'm glad to help! :D
