Margins for Annotation
moelski
Post by moelski » Thu Oct 22, 2009 11:48 am
Hi !
I really miss a feature for the annotations - margins.
If you set the position you can only choose an Auto mode like "Right top" Left top" ... or you choose "Custom".
In most cases the Auto selection is ok, but it would be great to set some margins even if it is set to auto mode.
I know it is possible to control the position of the annotation manually, but it would be nicer if this could be done by TChart directly.
So what do you think about that suggestion?
Greetz Dominik
Re: Margins for Annotation
Post by Yeray » Thu Oct 22, 2009 2:15 pm
Hi Dominik,
I'll add this to the wish list but (TV52014508), as you know, this is quite easy to do manually. For example:
uses teetools;
var annotation1: TAnnotationTool;
  annotation1:=Chart1.Tools.Add(TAnnotationTool.Create(self)) as TAnnotationTool;
  annotation1.Position:=ppLeftTop;
  annotation1.Text:='Annotation with margin';
var LeftMargin, TopMargin, tmpLeft, tmpTop: Integer;
  LeftMargin:=10;
  TopMargin:=10;
  tmpLeft:=annotation1.Bounds.Left;
  tmpTop:=annotation1.Bounds.Top;
  annotation1.PositionUnits:=muPixels;
  annotation1.Shape.Left:=tmpLeft+LeftMargin;
  annotation1.Shape.Top:=tmpTop+TopMargin;
moelski
Post by moelski » Fri Oct 23, 2009 5:53 am
For sure. This is an easy task.
But we have one problem ... We store the TEE file in a Stream. If we load it back the values for the margins are gone:
  LeftMargin:=10;
  TopMargin:=10;
We had to store this information by ourself.
And on the other side we got the same "problem" after loading. We have to read the values and set the margins to a new value.
Another probloem is while resizing the chart. We have to manually control all the positions of annotations.
So there are a lot of things to do which will better done by TChart itself.
Post by Yeray » Fri Oct 23, 2009 8:03 am
Hi Dominik,
Yes, I understand that's annoying to do this job manually. I only wanted to clarify that there is a way to do it while it's not included in TeeChart sources.
moelski
Post by moelski » Fri Oct 23, 2009 8:11 am
Ok. Thx
Could you imagine when it will be included? I think it´s not such a hugh change in the sources.
But many other tools (like rectangle) will profit from that.
Post by Narcís » Fri Oct 23, 2009 8:56 am
Hi moelski,
Sorry but we are not able to provide an estimate date for now. However, I'm pretty sure that if it's implemented it won't be in v8 but in next major release. Please be aware at this forum or subscribe to our RSS news feed for new release announcements and what's implemented on them.
Probably not but this is quite a specific need which anybody else requested so far. You must understand we have to give feature requests a priority level considering the general interests of TeeChart users among other criterion. Being a source code customer also gives you the option to customize sources to fit your exact needs.
