Sort Area Series by last value
TestAlways
Post by TestAlways » Thu Mar 18, 2010 4:53 pm
I have a chart that has a number of area series. I would like to z-order the series with the one in the back with the highest last-value of the series, and the one in the front lowest last value of the series.
How can I do that?
Ed Dressel
Re: Sort Area Series by last value
Post by Yeray » Mon Mar 22, 2010 3:21 pm
Hi Ed,
Is the following what you are trying to do?
uses series;
var i: Integer;
  for i:=0 to 3 do with Chart1.AddSeries(TAreaSeries.Create(self)) do FillSampleValues();
var i, n: Integer;
    swapped: Boolean;
  n:=Chart1.SeriesCount;
  swapped:=true;
  while swapped do
    swapped:=false;
    for i:=0 to n-2 do
      if Chart1[i].YValue[Chart1[i].Count-1] < Chart1[i+1].YValue[Chart1[i+1].Count-1] then
        Chart1.ExchangeSeries(i, i+1);
        swapped:=true;
    n:=n-1;
