we have to position a SubChart outside the Chart Axis, e.g. under the Chart.Legend. Because the SubChart should not hide any info of the Main chart, but if we try this to position the SubChart under the Legend there are many problems :
procedure TGraphForm.ChartIntResize(Sender: TObject);
ChartTool3.Charts[0].Chart.Left := ChartInt.Legend.Left -50 ;
ChartTool3.Charts[0].Chart.Top := ChartInt.Height - ChartTool3.Charts[0].Chart.Height -50 ;
This code does not function well, because there is now way to deal with Form maximize and if only the Chart is resizing the SubChart is only following very slow the Main Chart Position.
Can you help us?
Your sincerely
Willi Ebert
Position of a SubChart
Re: Position of a SubChart
Hi Willi,
Could you please attach a simple example project we can run "as-is" to reproduce the problem here?
- Newbie
Hello Narcís,
here is a test project. The SubChart stays not under the legend like it is defined in the Chart1Resize procedure.
Your sincerely
Willi
Your sincerely
Willi
- SubChart.zip
- (12.33 KiB) Downloaded 454 times
Hi Willi,
Implementing OnResize as shown below works fine for me here. Chart needs to be drawn so that legend properties have correct values.
procedure TForm2.Chart1Resize(Sender: TObject);
Chart1.Draw;
ChartTool1.Charts[0].Chart.Left := Chart1.Legend.Left -50 ;
ChartTool1.Charts[0].Chart.Top := Chart1.Legend.ShapeBounds.Bottom;
- Newbie
Hello Narcís,
thank you very much for your help. Chart1.Draw was the key.
Your sincerely
Willi Ebert
Your sincerely
Willi Ebert
