How to detect pie slice on mouse move
rloewy
Post by rloewy » Fri Apr 08, 2011 4:17 pm
Is there any way to detect what pie slice the mouse is over - the way we recognize it in the SeriesClick event for example - where the ValueIndex tells you the slice?
I want to use this to animate the slide the user is on by exploding it - for a more dynamic look.
procedure TForm5.Series1Click(Sender: TChartSeries; ValueIndex: Integer;
Button: TMouseButton; Shift: TShiftState; X, Y: Integer);
Re: How to detect pie slice on mouse move
Post by Yeray » Mon Apr 11, 2011 2:21 pm
You could use the Clicked event in the OnMouseMove event. Here it is an example of it:
uses Series;
  Chart1.AddSeries(TPieSeries).FillSampleValues();
  Y: Integer);
var ClickedIndex, i, tmp: Integer;
  ClickedIndex:=Chart1[0].Clicked(X,Y);
  if ClickedIndex>-1 then
    for i:=0 to Chart1[0].Count-1 do
      if i=ClickedIndex then tmp:=15
      else tmp:=0;
      (Chart1[0] as TPieSeries).ExplodedSlice[i]:=tmp;
rloewy
Post by rloewy » Mon Apr 11, 2011 4:03 pm
