I'm trying to fill a polygon with brush.bitmap using TDraw3D and TTeeOpenGL (TeeChart 7.07 Pro Delphi7),
but PolygonWithZ, Plane3D or TriangleWithZ don't work.
(while Cube, Cylinder work fine)
Where is the problem?
Maurizio R.
TDraw3D - filling polygon with brush.bitmap
Re: TDraw3D - filling polygon with brush.bitmap
Hi Maurizio,
Could you please attach a simple example project we can run "as-is" to reproduce the problem here?
Ok,
I attach a sample Project to test.
Thanks for your support.
Maurizio R.
Maurizio R.
- SampleTDraw3DBrushBitmap.zip
- (148.76 KiB) Downloaded 466 times
Hi Maurizio,
Thanks for the example project. I'm afraid this is a bug which I have added to the defect list (TV52015754) to be investigated.
